I did view a thread with a problem similar to mine. However that related to a non functioning digital display. Ours is an intermittent display. It can most often be overcome by banging the oven door closed repeatedly. I believe therefore the problem is a poor contact somewhere. I have cleaned with abrasive what I believe are the 2 power leads to the panel. I have not removed any of the other connections to the panel display. But I did liberally spray them with an electrical contact cleaner. From an automotive point of view I would suspect a faulty ground connection. However being unfamiliar with appliances I don't know if that is relevant. I suspect it is not a parts replacement issue. Help would be appreciated to point me in the right direction. All the functions of the both ovens work it is only being able to read the digital display panel that is intermittent. First post. Thank you for assisting me.
