I inherited this Viking stove when I bought the house. A couple of years ago, the right front burner would continuously click after lit. It only happened occasionally at first, then was every time. I took the stove apart to troubleshoot. The problem seemed to be the wire from the switch to the control module, so I moved it to the back burner and forgot about it. Fast forward to now, it's hit the top of my list of things to get done. I replaced the wire that I explained and nothing changed. Based on my internet research, it seemed the next logical part to replace was the spark module.
I replaced the spark module and now the problem is worse. Now, in order to get the stove to stop sparking all 4 burners, I have to either have both back or both front burners running. If I shut one off, they all start sparking again. If I shut them all off, they all stop sparking. I've tried moving wires, I've checked continuity in the wires, I've moved ignitors, nothing changes. I'm sure it's a simple solution, I just can seem to figure it out. Any help would be greatly appreciated.
