liviekins
#1 Posted : Tuesday, February 23, 2021 7:53:27 AM(UTC)
liviekins
Canada
I was washing a load of clothes and noticed that it was running a lot longer than usual. Upon investigation, I found that the machine was making a buzzing sound. I turned it off and opened the washer to find my clothes were still soaked. I tried to re-run another cycle and this time it filled and did nothing else while still making the buzzing sound. It also started emitting somewhat of a burning smell. I am including a recording of the buzzing sound here.
I've tried to do some troubleshooting and I'm thinking it could be the drain pump? Please let me know if you have any insight on the issue on how I can go about fixing this issue! Thank you!
Edit: a sock had somehow gotten into the drain pump causing it to jam. Removed the blockage and it is working fine now.
Edited by user Sunday, February 28, 2021 9:56:51 AM(UTC)  | Reason: Fixed
