Joined: 2/9/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: MA
My washer (Maytag MVWC400XW3) was not spinning and I have replaced the shift actuator. After that it makes very loud noise (like a jet taking off) while spinning. And it seems that the spin takes much longer than usual. At some point I even thought that it is not going to stop at all. What might be wrong? [UPDATE] I had the following error code before I changed the shift actuator. F2E1 - Centennial washer control key has been pressed for more than 15 seconds. F7E1 - Centennial washer basket speed sensor fault (BTW, another issue, I have tried to clear error codes, but somehow it does not do it. I pressed the "Start" button for 3 seconds after I got the codes, but codes are still there. After I replaced the actuator, I tried to wash some towels and got an additional code: F7E6 - Centennial washer motor fault I have unplugged the washer, but it did not change anything. What can I do? Edited by user Tuesday, February 9, 2021 4:25:48 PM(UTC)
| Reason: Added error codes
I have recallibrated the washer and ran the automated test and now it shows me an error code F15E0. I can't find it anywhere. What does this code mean?
