AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Top LED light panel (only) not working, rest of the lights working
Joined: 7/15/2012(UTC) Posts: 0   Location: 2426 Aquasanta
The top LED Light Panel on the Fridge side just stopped working however the side lights in the back and LED Temp still work so the top LED light panel was ordered and replaced but the new one is also not working. Switch also just started to stick and not turn on any lights but when the switch is tapped the back lights and LED temp lights come on again. Is this the switch or is there some transformer for just the top LED panel that could be the problem?
