AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Damper wires corroded loose on Haier refrigerator -- lower drawer
Hello, I have a Haier refrigerator PRCS25TDAS model which has french doors and a lower drawer for keeping / cooling drinks. This lower drawer has stopped cooling, and upon inspection I noticed that the damper wasn't opening anymore. When i went to take it off, I noticed that almost all of the six wires going to the connector from the refrigerator side had corroded loose. The problem is that there doesn't seem to be an access panel either from inside or externally on this refrigerator. If I could access it, then it would be a matter of re-wiring to the connector and issue solved. Does anyone know how I could access the wiring? I checked the back and removed a few panels but didn't see any access points. Or is this just a lost cause at this point? Thanks in advance Edited by user Thursday, February 4, 2021 10:44:27 AM(UTC)
| Reason: Not specified
