AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
top freezer refrigerator - holding temp but LED temp/control panel not lit
Kenmore Model 795.75312.900 – top freezer with internal ice-maker and external filtered water The refrigerator seems to have some kind of electrical or wiring hic-cup. I tried flipping the breaker a few times to get it to restart. For 24 hours the refrigerator stopped cooling but the freezer stayed cold. Technician found that the freezer fan was not running. I agreed to order the part and get it repaired when the part came in. Four hours after techn left, the fan started up again of its own accord. Currently the refrigerator and freezer seem to be holding temperature. However, the LED temperature and control panel (inside the refrigerator) is not lit up.
I asked the Tech if the LED temperature and control panel (mechanism?) could be replaced. He said the part was no longer being manufactured.
Question: Can the LED temperature and control panel be fixed? Reset?
