My wife powered off our icemaker due to an unusual amount of noise. when we powered back on, noise was gone but light to change filter came on. we changed filter then light came on to clean the unit.
I have drained the icemaker but when I fill the pan with cleaner and water, I see liquid come out a drain hose inside the unit. When I pressed the clean button to on, it disp[alyed a message to "add cleaner". I add more cleaner and water but liquid continues to drain out of the vertical white rubber house inside leading from the pan and the light remains on.
Any idea of what's going on or how I can repair?
