I have a Viking dual fuel range. It’s about 3 years old. The electric oven started having the following problem. When you turn the oven on, for a few moments the oven light comes on blue(normal) but then the self clean light comes on blue and the oven light starts flashing. The oven doesn’t heat. I read online the suggestion to turn off the breaker to reset the electronics, but that had no effect. Any ideas?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Did you ever figure this out? I'm having the same issue.
