Bullwinkle
#1 Posted : Monday, November 30, 2020 12:28:27 PM(UTC)
Bullwinkle
United States
New to the board and I have a problem I need help with. I did the search for this model of gas dryer but nothing came up. The dryer stopped heating over the weekend. I did some searches and found that the thermistor is the most common thing that causes this. I replaced it but nothing changed. During my testing after replacing the thermistor, I found that the dryer shuts off after 3 minutes when you have it set on Time Dry and 40 minutes or 30 minutes with high heat. It doesn't do that on low heat or 20 minutes timer.
Could this be a separate problem or is it related to no heat?
TYIA
Randy
