kaigoss
#1 Posted : Saturday, November 28, 2020 6:43:09 AM(UTC)
kaigoss
United States
Hello, we have a Bosch NEXXT 300 dryer. The model number is wtmc332bus/06. There is no power to the unit, i.e. the control panel does not light up. What I have checked so far:
1. Breaker not tripped (measuring 250V at outlet)
2. Power relay 422203 working (I replaced it because existing one was burnt)
3. Belt switch has continuity and belt is on
4. High limit thermal fuse not tripped and has continuity
5. Control board replaced
I'm kind of at a loss as to what else to check. Is there maybe another switch that could be interrupting power to the control panel? Thanks in advance!
Kai
