My Maytag Neptune shakes very bad when starting the initial wash cycle. Its not bearings, support shocks or damaged balance ring. It seems that the back and forth cycles used to be gentle tumbling motions in each direction. Now the drum spins up fairly fast in both directions causing the clothes and drum balance to not catch up with each other. Is this a motor control issue?
