AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Strange clicking with electronic buzz rinse/wash
Maytag MVWC415EW2 / Commercial Edition Has a Splutch, took it off and had some grease on it. There was some wear but not sure it was enough to cause a problem. Agitator seems to spin and there is a slight smell of burning rubber like a vacuum belt. Its hard to tell because when you open it stops, but appears to have momentum. I able to spin tub and agitator by hand. I have considered Starter Cap, Splutch, and Actuator. I don't think the transmission is stuck since I can turn it. Any Idea which part it may need ? https://photos.app.goo.gl/qdFk77EEmnqm6NeV8Update : Just Ran the Diagnostic Display Mode and Got an F7 E6 Motor Fault Edited by user Friday, October 30, 2020 1:34:26 PM(UTC)
| Reason: Not specified
Washer Repair
