Joined: 10/19/2020(UTC) Posts: 0  Location: Bowie Maryland
I have a Maytag Legacy Electric Dryer Model MDE508DAYW. I had a problem with noise (like tennis shoes was in the dryer)so I changed both Drum support rollers following the instructional video. I encountered no problem installing the rollers, but when I start reassembling the dryer I encountered 2 wires that I do not remember unplugging. The wires to the door light and the switch are the only wires I removed. One wire is green with yellow stripe (probably ground) and the second wire is blue. Both are coming from the control panel.
