Hello. I have a Kenmore Elite 79571052010 That is not getting cold enough. Fridge is 45-50 degrees F. I set the temps to 0 freezer and 34 on the fridge. Unplugged it and waited 5 mins ( no change )
Things I have checked . I can hear and feel the compressor running ( it's hot) Coils are not hot or warm. But I never really hear it click on or off . There was no Ice on the coils. I would assume that I should hear it kick on now and then but it just runs at the same speed all the time .
1) both Fans are working. Checked the one in the freezer and the one for the coils on the outside rear. Cleaned the coils.
2) Checked the capacitors. They charge and discharge.
3) Replaced the Temp sensor in the freezer compartment.
That's all I really know what to check. All I have is a digital multimeter.
Thank you in advance for any help. Stay Safe.
Troy.
