Chris T
#1 Posted : Monday, October 5, 2020 4:01:07 PM(UTC)
Chris T
United States
I am hoping someone can lend me some advise. About three weeks ago my Jenn Air Gas Range JDS8850AAB stopped mid-baking and fllashed the error code f1-1 and shut itself off. After a little research I replaced the temperature sensor(OHM sensor and harness) hoping it was the easy fix. After firing it back up it failed again during preheating and flashed the same error codes. I then ordered a replacement control board and replaced it just this weekend. I set the temp to 350 and let it bake for 15 minutes with no issues BUT I realized the convection bake no longer worked nor did the oven light. Last night I used it to heat two meals for 20 min at 425 and at the 10 min mark it shut down and flashed an error code f3. Ughhh Before I buy a new range I want to be sure it isnt a $20 part. I say this because when I replaced the temperature sensor I only replaced the sensor/not the harness that I assume connects the sensor to the control board. I really dont want to throw any more money at this issue unless you feel it is a cheap fix. Any advice is appreciated.
Chris
