karma2000
#1 Posted : Monday, October 5, 2020 9:26:14 AM(UTC)
karma2000
Canada
Started with warm refrigerator - both freezer and fridge.
Tech came and after a weeks wait - replaced the lower evaporator coil assembly
Since then fridge only held temperature for couple of days.
- Tech refilled gas, but again back to not holding temperature.
- Still cools but Freezer at 12 and Fridge at 54 ..not 0 and 39.
- Ice trays hold ice in the freezer, but frozen food is not ice cold.
- Fan is working
Opened the back panel.
Lots of solid ice buildup in the right corner side
- Absolutely, no ice in/around the drain hole this time or the bottom of coils
Used hair dryer to melt the ice.
Had the freezer ON for 4hrs and re-checked the coils- Again build up of ice on the right top capillary?
What was missed or can it be fixed?
[img=https://imgur.com/1FBOK4n]Kenmore Double Door Fridge not cooling enough[/img]
[img=https://hosting.photobucket.com/images/i/karm]Kenmore Fridge[/img]
Edited by user Monday, October 5, 2020 9:30:31 AM(UTC)  | Reason: Not specified
