The oven preheats, then the ignighter and burner shut off as expected. When the temperature drops the ignighter goes on for maybe 15 seconds and then shuts off for 15 seconds. The burner never goes on. This continues. If I shut the oven off and on again it will go into preheat mode get to temperature and the same thing happens when it drops again.
Replaced controller board and temperature sensor.
Shouldn't the ignighter stay on indefinitely as long as the temperature is lower than the setting?
I'm confused. Any help is greatly appreciated.
Model# prg366gh
