Joined: 5/9/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: FL
Hello, noticed my Admiral AAV7000AWW will no longer spin after a heavy load (sheets/blankets). Took the unit mostly apart, and can see the pulley system/belt will still spin. Also the agitator will work on wash, the pump will drain the water, but the barrel will not spin on spin cycle. Any ideas? Is the likely fix worth replacement or purchase of a new unit (it is likely 14 years old). Thank you much!
