Fridge stopped cooling, found PTC relay was broken/fried (possible due to power outtage/blip), was able to jump R to S (for a sec) to get comp running while waiting for new relay (61005518).
Installed new relay, it started but then immediatly started cooking the new relay again! Removed newly fried relay, manual jump start still works and comp seems to run just fine this way.
Did I install the wrong relay? Is there something else that would cause this?
Thanks very much for your help!
