Frigidare GALLERY SERIES GLEB30S8ABA MFG 8/2002
Reading many posts I started troubleshooting.
1. the broil function works,,bake does not 2. bake element reads 19ohms resistance (not open) 3. no AC voltage at bake element temp set to 350, I think I should have seen 230VAC 4, cannot identify thermal switch as diagram is not very clear
Using the schematic and tracing circuits...... I'm thinking the relay on the control board, no voltage at element, good continuity of element, and broil works (thermal switch ok?)......
opinions?
