Joined: 8/1/2020(UTC) Posts: 0  Location: North Dakota
Hello all,
I'm out of ideas on what else to do with this fridge except junk it or call the repair guy. Already have $200 into parts. The freezer sits at about -10 set at the 1 setting, which doesn't seem right... The forced defrost mode works. I've replaced the jazz board, the defrost thermostat, and the freezer thermistor. The defrost element has continuity. When through the diagnostics and everything else passed the tests. It takes about three weeks to freeze up after I manually defrost it. What else can be done?
