Joined: 7/20/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: AZ
About two weeks ago My washing machine started getting an 8C code. I tried unplugging it for 30min to restart it. I also replaced the control board and the MEMS sensor. It is still giving me an 8C code. When I first start the washer, the start up process begins and it starts to fill. very shortly after starting to fill the code will come up, the washer will drain and then attempt to resort the cycle, over and over. If I use the power off button and try a new wash cycle, it will run the drain, then never start the cycle and just freeze. I don't want to keep buying parts. What do I need to fix? Thanks for any help!
