I have a fridgidare dryer that won’t start. It has the E66 code and I have checked the thermal limiter and the fuse and all are fine. They have 120 volts to them and through them. I have replaced the electronic control board. No change. I have 56 volts to the heating elements all the time. Wire comes from the motor and goes to the elements. Any help out there?
Try another forum but include a model number Edited by user Sunday, July 19, 2020 12:51:28 PM(UTC)
| Reason: Not specified |
THIS FORUM IS DEAD!!!!!!! |
