Hello all, i am need of an experts help. I have a Frigidaire Affinity Dryer AGQ6700FS2 dryer, it just started beeping and wont run for more than a minute. I ran the error code reading procedure but after simultaneously pressing the SELECT and CANCEL button for 6 seconds, the buzzer will sound once but the LCD readout shows the timer "1:00" and not "rES". So i am unable to retrieve an error code. However, when i run the Test Sequence and get to "4 Turns" and when the DRYNESS key is pressed, all the dryness level LED's DO NOT light up. The rest of the TURNS and test sequence procedures were successful. So to a novice like me it seems a need a new control board or a new "Dryness" button. My question is why cant i get the dryer to give me an error code? And do i need a new control board or just a new button? Please help! Thanks.
