wadeoPGH
#1 Posted : Monday, June 22, 2020 8:13:18 AM(UTC)
wadeoPGH
United States
Today after recharge temps were dropping got to about 45 and then the tech left and I noticed that the compressor cut off, and we were not down to the 36-degree setting.
The compressor and evap fan are not running, the controls are digital and set to 36 currently with a current inside temp of over 70.
I wonder what I should be looking at if the cooling side of this is not running, the interior recirculating fan is running and controls are error-free.
For good measure, I had an extra control board laying around as the original one was going kinda bonkers and would simply start and stop at random not keeping a consistent temp at all but would start and run at random. The new board resolved this random starting issue.
So I put this board into at least rule out the control computer being the culprit. With this control board in place, it made no difference at all. The compressor/evap fan are not starting. I swapped them back, made no difference.
What should I be looking at that controls both the Compressor and Evap fan.
Thanks!
wadeoPGH
#2 Posted : Friday, June 26, 2020 9:55:36 AM(UTC)
wadeoPGH
United States
Tech came back out to take a look, the compressor, and condenser fan both work when manually started. The control board is faulty. This is the second one, I'm getting about 2 years per board... ugh
My question is there a universal control board for beverage refrigerators that can be modified to work on all of these refrigerators? They are pretty basic machines, this should not be too difficult.
