Hi, I have a GE double oven P/N jkp27b0w2bb. I've had several errors show up, F2, F3 and F5 and the oven shuts off when this happens. I replaced the oven sensor, but am still seeing the F2 error. I think that the control panel needs to be replaced, but I can't find the part number for the panel to even do a search. It's an old oven and the bottom oven works fine, but the top oven has these errors occur when the temp is 400 degrees or over. Any help would be appreciated. SteveG Edited by user 5 years ago
| Reason: Not specified
