Joined: 6/11/2020(UTC) Posts: 0  Location: Charleston, SC
The oven would barely heat and not go above 300F. I opened it up and saw the inner heating element quick-disconnect (QD) had fallen off of one of the inner element plugs. Both plugs on the inner element were eroded by sparks / current. Female connectors look fine. Outer element looks fine. I labeled the outer element wires and have the replacement. I took off the label of one of the outer elements before I hooked it up and now I have 3 unlabeled wires. I took my best guess, crimped all QDs and it seems OK on a 30 second test. How can I really verify that the wires are correct? Will it work at all if I have element wires swapped? Edited by user Thursday, June 11, 2020 5:29:39 AM(UTC)
| Reason: Not specified
