Emailtim
#1 Posted : Friday, June 5, 2020 1:49:05 PM(UTC)
Emailtim
United States
I am getting an LE error. I have replaced the rotor, the stator and the hall sensor.
The rotor still does not want to turn on its own. However, if I give the rotor a little push, even the wrong direction it "wakes up" and will begin to turn.
I'm at a loss.
Emailtim
#2 Posted : Saturday, June 6, 2020 1:30:08 PM(UTC)
Emailtim
United States
I may have finally found the issue. One of the blue wires in the wiring harness is testing negative for continuity. New harness will be here tomorrow.
