AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag MVWC4658W2 Door switch? Will drain but not spin.
Hi: This washer is just beyond the reach of the 2 year warranty. When I put it on a wash cycle, the sensing unit goes on and off and eventually fills the tub with water (too much, imo). The door locks and I can get it to drain by turning the dial to drain and spin, but it won't spin.
I tested the door switch for continuity. When door is shut, it completes the circuit. When door is open, no continuity. So figured that was okay? Did not want to release the locked door, even after pressing the cancel button, or by unplugging. By lifting the top cover of the washer, I was able to eventually free the locked door.
What should I try next?
Thank you.
Jim
Washer Repair
