supra-raleigh
#1 Posted : 5 years ago
supra-raleigh
United States
The Kickstart capacitor bubbles out fluid when I press the contactor button/plunger. I priced an identical new capacitor and they are not cheap. The cheapest one I saw was around $180. The part# is 5162718 or KSTS324 or HC95DE042
324-356MFD
330VAC
I found a cheaper one on the Grainger website for alot less.
But, the specs are not identical. The specs are:
216-259MFD
330VAC
Made by Packard #44ZU51 $17.20 This one has a resistor soldered into the terminals like the Kickstart Capacitor.
I also found one with the following specs:
DAYTON
Round Motor Start Capacitor,300-360 Microfarad Rating,330VAC Voltage Item # 2MEP7 $55.50. This one does not have a resistor soldered into the terminals.
Can one of these or some other capacitor be used as an alternative to the original Kickstart capacitor?
Thanks very much
Edited by user 5 years ago  | Reason: Not specified
supra-raleigh
#2 Posted : 5 years ago
supra-raleigh
United States
Also, I have searched for the relay for the kit, but I can't find it other than purchasing the Kickstart kit #HC95DA401
It is a 5-2-1 relay. Can I just get another 5-2-1 relay from some other kit? I ask because other kits I see have a 5-2-1 relay for much cheaper. So, in other words I would like to replace the capacitor with an alternative to the expensive Kickstart one and source the relay elsewhere for cheaper. Thanks for any advice.
supra-raleigh
#3 Posted : 5 years ago
supra-raleigh
United States
One more thing... The COMM STATUS amber light is blinking. It blinks 6 times and pauses and then repeats.
supra-raleigh
#4 Posted : 5 years ago
supra-raleigh
United States
I fixed it with this:
5-2-1 Compressor Saver CSRU3 Hard Start Capacitor For 4-5 Tons.
