Jaslikow
#1 Posted : Monday, May 25, 2020 2:21:37 PM(UTC)
Jaslikow
United States
I have a Samsung WF210ANW front load washer. I've previously replaced the drain pump and door seal. Right now I've noticed that with the frame level to the ground the tub has a severe tilt downward causing water to pool towards the back of the tub. The washer shakes while accelerating up to spin speed but is steady at constant speed. Do I need new shocks or something else? There is no obvious damage to the shocks or suspension springs. Thank you,
Adam
