mgscott
#1 Posted : Tuesday, May 19, 2020 12:20:07 PM(UTC)
mgscott
Belize
Hello,
Thanks for letting me post. I have a Maytag MDc8959aws2 and just recently the "normal" light [under the cycles section of the keypad] keeps blinking. I have tried disconnecting it from the electrical outlet and have even turned off the breaker to reset it but the light keeps blinking. There was a point that the "normal" and "cancel" lights were both blinking but after turning it off/on again, the "normal" light just blinks. I cannot get the dishwasher to operate. After some research, it appears that this blink would suggest that either of the following need replacing:
1. Keypad
2. Control Board
3. Keypad and Control Board
Given that there is a substantial price difference between the keypad and control board, is there a way to test to see what the root cause of the problem is? Additionally, do you suspect that I have narrowed my search too much and there could be other issues I have overlooking? Thanks for you help!
-m
Edited by user Tuesday, May 19, 2020 12:21:23 PM(UTC)  | Reason: Not specified
