Joined: 5/15/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Honolulu
I replaced the tub seal and put it back together and now it wont power on. I double and triple checked that everything is plugged in. I did some testing:
I have 120V coming out of the noise filter
I have 120V at pin 1 and 3 of CN5
I have 120V at pin 1 of CN5 and pin 1 of CN6
I see some mentions of the door switch causing the machine to not work. Would a faulty door switch cause the machine to not turn on at all (no lights, etc)?
Thank you,
-g
