our diswasher is a GE gldt696j00ss the dishwasher only want to run if i push the door in an extra 1/4. i have check the door seal for blockage and everything looks good. I didnt see that there was a way to adjust the door springs. I ended up putting a small piece of tape on the door latch limit switch button. and that is working for now. does this mean i need to replace the door latch or maybe just the limit switches in the door latch?
Thanks all
