aarondahmen
#1 Posted : Friday, May 1, 2020 1:02:37 PM(UTC)
aarondahmen
Afternoon,
My icemaker has quit working. Makes no ice whatsoever. Water dispenser works perfectly fine still.
I did notice that the light / beam that triggers the icemaker to be on / off was no longer working - and before delving into the forums, purchased a replacement part for that piece thinking the light may have been broken - still does not work or light up.
After a bit of research I came across the diagnostic mode and played with it.
36 Ice box fan - WORKS
37 thermosistor - PASS
45 ice maker fill - WORKS
56 - E0 - no errors..
57 harvest - no response - does not do anything or make sounds
59 motor - no response - does not do anything or make sounds
Based on the above, I would assume the motor is not responding, but I'm not getting any errors on 56... could this still be a motor / maker issue or am I missing something?
Please assist if able and thank you for your time,
Aaron
