Switched on a completely new Asko oven, set up the regime for cooking, but the display kept showing 'The door is open', while the door was obviously closed. Tried several times, all the same result: 'The door is open'. Finally, after four or five times it started heating up, but then it suddenly shorted out half of other appliances in the kitchen and the display showed 'Err6'. I immediately unplugged it. Already called the company and waiting for the response.
But maybe anyone has had similar issues with the oven door? Could it be that the minor issue with the door lockings that prevented somehow the proper door closing? Haven't found any info regarding asko ovens on the web, already dissapointed in brand
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
G'day May I ask what results you had thanks. My oven has just done the same thing. Thanks Pete
