mgandhd
#1 Posted : Wednesday, April 29, 2020 9:16:12 AM(UTC)
mgandhd
United States
My dishwasher has the blinking "Clean" light, but otherwise won't work, If I press "Cancel" it will appear to run for a bit and then stop with the "Clean" light back to blinking. I tried to reset, but nothing seems to work. I have also turned fuse on and off. When I put it back on, the "Clean" light was back. Water temp on tap is plenty hot. Could a simply reset work? And if yes, what is the proper process for resetting this model? Else, what can I try? Thank you!
