Joined: 4/26/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Wisconsin
Washer was not agitating and spinning correctly. I had a 4 light blinking code and had no ohms when testing the mode shifter on the drive shaft, so I replaced the assembly. The mode shifter now seems to be working ok since I can hear it engage and disengage. The washer agitates good but does not constantly run fast in the spin cycle and now only run slower in the spin cycle. I now have an 8 light code indicating that the motor overheated. The motor does not seem to hot, and the motor seems to work fine except now the washer does not spin fast. Can anyone give me any suggestions I do not want to buy a new motor and find that is not the problem.
