Bill Vines
#1 Posted : Wednesday, April 22, 2020 12:46:18 PM(UTC)
Bill Vines
United States
Freezer does not keep set themp. The reading on then door says 4 degrees but thermometer in side says 40 degrees. If I set the thermostat to super freeze the temp goes to 20 degrees.It appears the freezer is confused as to the real temp.Any suggestions?
