I need a little help or advice on this. The machine bangs around and is out of balance way to easily. All of the suspension springs are in place. The little plastic cap above the spring seems to ride up the rod, not sure if that matters. Should there be tub centering springs on the left side? Anything else I should check or replace. Thanks, Jason
