I have replaced the water filter base and inserted the hoses back properly however, water is still leaking from the same area. The leak stops for a day or two and then starts trickling again. I am thinking that the water lines might need to be replaced as maybe one is cracked or pinched or something. Do you know where I can order the lines from? Also, how difficult of a repair is it to do yourself? Thank you, Mark Edited by user Monday, April 20, 2020 7:39:49 AM(UTC)
| Reason: Not specified
