I a have a Maytag A9600. On both cycles ( regular and Pem. Press) it stops at the rinse cycle and will not advance and no water comes out. It makes a low humming noise when it stops. It fills with water and runs through the wash cycle and does drains the water. I can manually move the dial to the spin cycle and it spin and will finish the cycle. When it spinning if I lift up top it will stop.
