My Frigidaire Refrigerator stopped working
Model FRS26R2AW8
There is light inside the refrigerator
I can hear the fan working.
The compressor is not humming or buzzing and is not hot to touch
Is this something can be fixed if I replace the board?
Any feedback is greatly appreciated
If you haven’t heard that sound in a while, your compressor may be broken. Pull your appliance away from the wall, and stand to listen for a few minutes and see if you hear the sound of a motor running, or a soft humming. If you don’t hear any noise, your compressor isn’t functioning. If you do hear a humming noise, but the food in your fridge is warm, your compressor may be functioning improperly
Need to check compressor for continuity. Many Youtube videos showing how it's done. If that checks good, check compressor start device. That would be first things I would check.
