pamaurel
#1 Posted : Wednesday, April 1, 2020 11:54:03 AM(UTC)
pamaurel
United States
I have a Frigidaire GLTF2940ES1 front load washer. It was not going into spin cycle or stopping mid cycle. Conducted the diagnostic tests and every mode was fine except for spin mode throwing error E57 i.e. high current on inverter. Conducted test #11 per the tech data sheet. Motor and tub appear to spin freely. Windings resistance were within specs. So I replaced the motor control board. Now it is even worse as I am getting the same E57 code just a second after starting the fill cycle. Could I have a bad replacement board, messed up something during the repair, or should I try replacing the motor at this time? Thank-you.
