Jmc3352
#1 Posted: : Monday, March 30, 2020 4:40:29 PM(UTC)
Jmc3352
United States
The problems started with the washer not working when trying to use hot water. It would work fine if using only cold water. When trying to run a cycle with warm or hot water there was a buzzing sound that I tracked back the hot inlet solenoid. I went thru the diagnostics and it was F8E1, which I assumed a slow water fill since no hot water was coming into the tub. I ordered and replaced the fill valve. After putting it all back together it is doing the same thing as before, and the hot water solenoid is buzzing again. The only I can figure out is that the new full valve is bad. Need help diagnosing this.
brobriffin
#2 Posted : Tuesday, March 31, 2020 6:05:23 PM(UTC)
brobriffin
Man
United States
Rule out bad solenoid by switching the power wire from the hot and cold solenoid. Run just a cold cycle, if you get the same issue (buzzing) on the cold valve it's a power/connection/wire/controlboard issue not a solenoid issue.
