Is there any way to test the refrigerant diverter motor valve on Model RFG297AARS. Typical fridge is fine but freezer not freezing and the display shows the freezer is below freezing but it does not freeze a test cup of water. All thermister are showing ohms when I freeze them in a cup of water in another freezer. Self diagnoses indicated the freezer fan motor failed so I replaced it. Now, no more codes but freezer still not freezing. Edited by user Saturday, March 28, 2020 6:35:43 AM(UTC)
| Reason: Not specified
