CanIDoIt?
#1 Posted : Wednesday, March 18, 2020 3:45:03 PM(UTC)
CanIDoIt?
United States
I have a kitchenaid KFEG500EWH0 that has recently starting having some heating issues.
When I set it to pre-heat to 400 it will very slowly get to about 350ish, maybe 360 and just hang out there. If I set it to 500 it'll get to 425ish slowly. The other day I had it at 425 and opened it to put the food in, then it immediately dropped back to 320 and started pre-heating again.
Is this a sensor issue? A thermostat issue? In either case I'd be able to replace it myself, I'm just not sure which I should try replacing first.
Any advice would be much appreciated!
Note that both the bottom, top, and rear convection elements have all been tested and are turning on during pre-heat so I am pretty sure it's not a bad element.
CanIDoIt?
#2 Posted : Friday, March 27, 2020 4:59:48 PM(UTC)
CanIDoIt?
United States
Update: I replaced the sensor and nothing has changed. I guess I'll try replacing the thermostat now.
