Joined: 3/14/2020(UTC) Posts: 0  Location: South Carolina
French door ice maker stopped producing ice. Ice bin sensors tested good. Replaced the ice maker fill valve. Have water through the door. Had water through the door before switching valve. Ice maker would not self start. Attempted to enter Diagnostics Service mode to run an ice maker harvest test but upon entering diagnostics mode the Service Test options stopped at Test #29. I need to run service tests #45,46,56,57. Any ideas what’s going on. Could this be an indication of a faulty control board? Model # WSF26C3EXW01
