Ljbrandt
#1 Posted : Sunday, March 8, 2020 7:50:57 AM(UTC)
Ljbrandt
United States
Whirlpool washer sounds and works normally on high speed agitation (and also fine while spinning), but only when running on low agitation does it make a strange buzzing noise which seems to be coming from the motor/transmission area. I recently replaced clutch and motor coupling, hoping it would solve, but no luck. Any ideas what could be causing this noise? It does not however seem to have an impact on performance.
